BMW e90 320D front brakes
Fuzz123
Hey guys thanks a lot for the great info in this thread. I dont wanna make a new thread and was hoping someone possibly found out something about back discs?
Is it as available as the fronts, or is it OEM only? :coolShake:
zippy320
Same situation as the front , though at the back on the E90 im not sure if its a solid disk or "vented" ? Im not sure what its called . Make sure you get the correct size disk.
I would personally go for either
Fibi Disks or Meyla Disks ...I lean More towards the Meyle but I have never had any problems ever with Fibi Disks ( they were also always cheaper).
And I always use Textar pads . I liked the BMW Pads a lot but they were always very price.And textar makes the BMW pads anyway.
Goldwagen told me that the sensor was R90 for the front , prob R120 for the back as it has a longer wire.
Disks I got from Goldwagen and Pads I got from Diesel Electric and I think
gizmo on the forum could also get you the Meyla Disks, you can PM him.
As a paste , I just use copper compound . I have been using it for years and found no issues . I think spanjaard makes it , it comes in a tube or a can , buy the tube it lasts long and its not as messy.
Try and do the brakes yourself , take a weekend , read about replacing the pads and disks , buy the correct tools and try it out for yourself , If I can do it anyone can seriously , I used to think that it was taboo to work on the pads etc because its a safety item but Honestly its so easy , I now work on my cars disks and pads because I find it more convenient to do it myself and I can do both sides in less then an hour with a little cleaning here and there.
Its not difficult . You must get one of those screw type piston compressor things as well to push the piston back into the caliper to make it easier to fit the new pads and then fit the caliper .
The back pads and disks generally last longer then the front ... well for me that is .
Good luck!
tman
Good luck!
"screw type piston compressor things" = C Clamp
Sent on the move via Tapatalk
tman
FILV said:
Star brake and clutch
textar pads R800
there brand discs R720
sensors 120
fitment i will ahve to source
Reviving an old thread...
Has anyone fitted Star Brake Discs? I just spoke to the guy there and he says its comparable to ATE.
2 front and 2 rear disks come in at R1800, which is R1400 cheaper than any other place I can find, (which is making me a little skeptical)
Reviews, suggestions?
Fuzz123
tman said:
textar pads R800
sensors 120
That sounds very cheap, I would also be skeptical! I eventually bought some Fibi discs from Goldwagen for R650 odd per disc for the rear and so far they have done well.
I just wouldnt trust something for that much cheaper than any other place, I mean BMW did localize a lot of parts for the E90 but that just sounds too good to be true.
