Wolfgang009
Hi all im new on the forum,
I am having problem with my e60 2007 525i. I have had the dsc light on since bought and wanted to fix it. I have scanned through Inpa and get several code from szl and dsc please see attached picture. I have changed the SZl unit and coded the new vin using tool32 but still same issue. My question is how do you remove or deactivate the brake air flaps from the car system as they are not mounted on the car and it seems to be in error list? And other question is on Ncsexpert I do not have the option to code my dsc when reading ecu the dsc just does not appear but I can read fault through inpa by going directly to chassis-dsc then read the faults. If someone could help would be greatfull I think it is a coding problem but not very familliar with ncs. Thanks
