BMW E46 330i - squeaky brakes
ele33
Hi guys, new to the forum.
I have a 2002 E46 330i, I replaced the brakes all around and its been squeaking ever since I've fitted them.
Its ATE pads.
Anyone else experience this? Is it the pads or could it be the discs?
beezo003
howzit der man
Welcome
If you go to midas you can ask them for their copper spary for squeaking
Maybe its just the new brakes needs to get worked in, but the copper spray should take the noise away
Bayn46
I have that problem in summer when the brakes get hot. The easiest solution is to take out the pads and apply some copper grease to the back of them, this prevents the squeaking in most cases.
Edit: Some of the manufacturers also recommend bedding in new pads to get the first layer or rubbish off the pads.
ClassicB
+1
You also get a anti squeak paste that goes on the back of the pads when fitting.
beezo003
bayn46 theirs a spray on one now exactly the same
No need to get hands dirty, i bawt the paste only to find out about the spray on
D
Dippies
Try using Copper slip and check the rattle plates if they are in the correct position .
ele33
Thanks for all the replies guys, they have been on for a few months now as I thought the noise would go away as they get worn in.
Think its best if i try the copper spray then!
Bayn46
Thanks for the info - will definitely grab some when I replace my pads. The grease is quite a pain to work with and spread evenly, but does a great job.
Rapido WP
You may just need to bed them in properly - go fast on an open road, then hit the brakes real HARD - that should remove any surface glaze. Be real careful with the copper slip
abmi0000
Its ATE pads.
Whats the condition of the discs? the old pads could've scorched the discs, thus creating a pattern in the disc that matched the old pads. The new pads will now have a perfectly flat surface against a possible ridged discs thus allowing for gap which also causes brake squeal.
Kurt Adv
Yup, mine squeal like mad, just fitted Ferodo pads all round, put Copperslip on too, still squeal....was thinking of getting ATE, but it seems others have issues with those too.......gonna try the 'hard braking' trick......
Nikhil
I have the exact same issue!, Im replacing the rears and fronts shortly with Bmw discs and pads :thumbs: its a friggen high pitched squeal! I have tried everything to stop this, copper slip only works for a week and then its back to normal again :yuck:
VeNoM_Ct
I have the same issue on my front brakes but that because it aftermarket pads... was fine at the time so why change it... but my front and back disks are OEM and rear pads.
I will change it soon the noise make me crazy :argh:
unikbarna
Wont this pop the airbag out?
:fencelook:
AdiS
:fencelook:
Why on earth would it do that?
danieljames
AdiS said:
:fencelook:
Because just by chance a fuse might blow causing the abs to fail. So he'll lock up and slide straight into a lightpost causing it to pop..........
M50B25-L6
S
SP33DYV
I use BMW discs and pads and have never had the squealing problem and I don't even use copper slip. :dropjaw:
