BMW E46 330i Ignition Feedback Resistor (ZSR)
Blomhj
Got some funny codes on a BMW PA Soft Scanner 1.4.0 , one of them is pointing to Ignition Feedback Resistor (ZSR) ...any ideas where this is located on an E46 .
Car runs fine no "check engine" lights and according to this codes the car should not even be running . Starts fine and runs all the way to 6000 Rpm no hiccups.
1D/64 - Ignition activation, cylinder 1, no ignition spark
1F/64 - Ignition activation, cylinder 5, no ignition spark
1E/64 - Ignition activation, cylinder 3, no ignition spark
D2/68 - Ignition current measurement, fault at more than 2 cylinders
03/64 - Ignition activation, cylinder 6, no ignition spark
01/64 - Ignition activation, cylinder 2, no ignition spark
02/64 - Ignition activation, cylinder 4, no ignition spark
Blomhj
Would have thought the same if it wast for the
D2/68 - Ignition current measurement, fault at more than 2 cylinders ( 210 Ignition Feedback Resistor (ZSR)) accompanied by the rest of the codes. Will change the plugs and check the coils as a matter of elimination just in case ..thanks!!
H|TM@N
Clear the codes, take the car for a short drive and see if they come back. Only then would I start replacing parts.
Philip Foglar
Yep, clear the codes and run the car for a few days, then check again. The fact that there are no performance issues is already a good sign. When last were the plugs changed?
Blomhj
OK so after getting my INPA to work ,I tackled this again . got this codes below. note the 210 ZSR Error (>2 Cyl.) error . It looks like the Feedback resistor line is broken or not getting signal or something . Happens at 1200rpm every time ....
Funny thing is car goes like a rocket no idle issues no starting issues , revs under load to 6000rpm etc etc ....
Your thoughts old wise ones ?
E R R O R M E M O R Y R E P O R T
Date: 11/02/14 18:41:44
ECU: MS430DS0
JobStatus: OKAY
Variant: MS430DS0
RESULT: 7 errors in error memory !
29 Ignition Zyl. 1
Error frequency : 4
Logistic counter: 40
N_32 1216.00 rpm
MAF 119.84 mg/stk
V_DUR_IGC_1 HIGH 0.00 ms
V_DUR_IGC_1 LOW 0.00 ms
aufgetreten vor (rel. BZ) 0.40 h
no Ignition spark
Error to not relevant
Error debounce
Error currently not available
sporadic Error
Errorcode: 1D A4 04 28 26 16 00 00 84 BA
31 Ignition Zyl. 5
Error frequency : 1
N_32 1248.00 rpm
MAF 130.73 mg/stk
V_DUR_IGC_5 HIGH 0.00 ms
V_DUR_IGC_5 LOW 0.00 ms
no Ignition spark
Error debounce
sporadic Error
Errorcode: 1F A4 01 28 27 18 00 00 84 BA
30 Ignition Zyl. 3
Error frequency : 1
N_32 1248.00 rpm
MAF 130.73 mg/stk
V_DUR_IGC_3 HIGH 0.00 ms
V_DUR_IGC_3 LOW 0.00 ms
no Ignition spark
Error debounce
sporadic Error
Errorcode: 1E A4 01 28 27 18 00 00 84 BA
Error frequency : 1
N_32 1984.00 rpm
MAF 136.18 mg/stk
TCO 93.75 Grad C
VB 13.97 V
ZSR Error (>2 Cyl.)
Error debounce
sporadic Error
Errorcode: D2 A8 01 28 3E 19 BD 89 84 BA
3 Ignition Zyl. 6
Error frequency : 2
N_32 1248.00 rpm
MAF 125.28 mg/stk
V_DUR_IGC_6 HIGH 0.00 ms
V_DUR_IGC_6 LOW 0.00 ms
no Ignition spark
Error debounce
sporadic Error
Errorcode: 03 A4 02 28 27 17 00 00 84 BA
1 Ignition Zyl. 2
Error frequency : 2
N_32 1216.00 rpm
MAF 125.28 mg/stk
V_DUR_IGC_2 HIGH 0.00 ms
V_DUR_IGC_2 LOW 0.00 ms
no Ignition spark
Error debounce
sporadic Error
Errorcode: 01 A4 02 28 26 17 00 00 84 BA
2 Ignition Zyl. 4
Error frequency : 1
N_32 1216.00 rpm
MAF 125.28 mg/stk
V_DUR_IGC_4 HIGH 0.00 ms
V_DUR_IGC_4 LOW 0.00 ms
no Ignition spark
Error debounce
sporadic Error
Errorcode: 02 A4 01 28 26 17 00 00 84 BA
