BMW E46 2004 Aircon?
Leon
Good day fellow fanatics
My 2004 320D is in need of some Aircon gas
Where in the Paarl / Northern Suburbs can I do this?
Who will you recommend?
Or is BMW your best bet?
Thanks:ty:
Kish2604
Administrator
Car has a leak in the system, air con is a closed loop system and should not need topping up/refill unless the system has been released of its contents or a break in the components.
Use a dye first at refill so it can be traced if there is a leak...
abmi0000
Spot on - There is never a need to re-gas unless you have a leak.
It would be like re-gassing your fridge.
Iceman007
Jip it must be a leak or its because the aircon was not used inthe winter at all this in turn causes the o-rings to shrink and you loose gas. to service your aircon every 2 years us a good thing and makes your system last longer.
Leon
Thanks!
Had the car for 2 months now!
Took it back to Paarlberg BMW and they did everything for free, and tested for leeks!
I have only had great service from the so far!:thumbs:
Leon said:
Thanks!
thats good to hear. :thumbs:
juan.nel.585
I need some help!! My E46 only cool on the passenger side. Driver's side doesn't cool. Can it be the filter? Pump is 100%, tested..
Waseem 333i
On a domestic fridge you should never need to refil gas unless there is a leak but on a car it is a different scenario. Using the aircon in temperatures exceeding 35 degrees causes the problem. The car aircon systems builds up too much pressure when used in those temperatures. There is a pressure valve somewhere in the system which dumps some of the pressure in turn loosing some gas. Over time you will need to do a refill. That however does not rule out the possibility of a leak. After the refill the car should be taken back in two weeks just to inspect for a leak.
