BMW E39 540i - Jandre's BMW gets detailed
M
Mike1
Hey Everyone
I am happy to share a detail I did for a fellow fanatic who recently acquired a beautiful BMW E39 540i.
This is of course Jandre's new Beemer which he booked in for a Full 2 day detail.
I arrived at the house in anticipation, looking forward to working on this beast of a car. After chatting for a bit we got the car outside and assessed what needed to be done.
It was immediately obvious that although a very well kept car, the paintwork had been neglected. Lacking any protection the paintwork had oxidized and over years of washing quite a few very bad swirls were also on display.
The bonnet and boot lid were by far the worse off, with very deep scratches, which although reduced I was not able to remove.
The mag wheels had also suffered with rust and discoloration on the lip of the mag wheel. The actual paint on the mags were also rather dull and lacking in gloss and definition.
In the engine bay things were a bit dirty, with a thick layer of dust on top of all the components and staining on the paintwork, plastics and huge amounts of dust. At this point I also noticed a lot of fine dust in the door shuts and boot shuts - I assume that the previous owner had used the car on a dirt road and didnt bother to clean these areas of the car.
With my observations out of the way I decided to get started on the car. Using Chemical Guys Extreme Strong Wash I set to work on the mags, tyres, arches and engine bay agitating with an assortment of brushes.
I then foamed the car down using Chemical Guys Maxi Suds allowing the car to soak for 10 minutes whilst the door shuts, badges, weather strips, bumper edges and trimmings were agitated by a brush.
After spraying the car down with a High Pressure Hose I gave the car a hand wash using a microfibre to remove any remaining dirt.
It was evident that this car had been a victim of some rather bad "Fall Out" as the paint was speckled with tiny spots of surface rust. To cure this and prepare the paintwork for polishing I used Auto Magic Clay to clay all the panels on the car.
Front fender alone:
The car was then rewashed and dried to reveal a very dull, lifeless and swirled paintwork. It was most upsetting to see her in this state so I began taping her up to begin with the correction.
Correction itself was completed with Chemical Guys Pro Cut No.2 (721) using a medium cut Hex Pad. This left me with very good cut, removing the oxidation (and constantly clogging my pads) and most of the swirling with relative ease.
Some 50/50's: (Some enhanced so its easy to see)
I must admit that I didnt really enjoy using the Pro Cut on this car as it left a very unrefined finish which is unusual as it was breaking down correctly and I was working it at the right speeds etc. So using a red finishing pad I solved this by using the Pro Polish from Chemical guys.
With the day drawing to a close I decided to layer the car with a single coat of Collonite 476 buffing off to leave this:
The second day of this detail started off with a quick wash, dry and yet another coat of Collonite further enhancing the finish. On the recommendation of a friend in the UK I also gave the car a single coat of Chemical Guys Wet Butter Wax on top of the Collonite.
Surprisingly this further added to the wetness and depth of the paint, I was positively thrilled as this is not a combination I would ever use as I find the Wet Butter Wax isnt very durable.
At this point I be-friended this friendly little kitty / coolant leak who continued to assist me (by purring and rubbing himself up against the car) as well as getting in my way. He made a fantastic buffing pad. :fencelook:
To be continued...
Continued...
With the interior now needing some love as began work. I was rather surprised that the interior with the exception of the rear seats showed very little signs of wear - I expected far worse based on cars I have done previously.
Spare tyre well was spruced up a bit:
The leather, fabrics, carpets and suede was cleaned and extracted leaving a fresh Cherry smell in the car along. The back seats cleaned:
With the detail drawing to a close it was time for the final little details:
- Glass was cleaned with Autoglym Fast Glass.
- Leather treated with Smart Leather.
- All trimmings, engine bay and tyres were treated with Smart Dressing.
- Mag wheels were clayed, polished with Megs NXT Metal Polish and given two coats of Rim Wax.
- Arches were doused in Trim Detailer.
- Door Shuts were waxed with XXX White Wax.
- Interior finishes were coated with some Gold Class Wax and buffed to a shine.
- Unfortunately the headlights were well and truly screwed, so we left those as they are in any case being replaced shortly.
The only thing left to do now was a quick photoshoot and a drive in Jandre's beautiful E34.
And to finish the day off, a beautiful sunset on my way home:
Thanks for reading, I think Jandre was rather chuffed with the finish on this new E39 and I thoroughly enjoyed my time working on her.
What do you think? All comments are welcome.
Mike
looks good, but the front lenses are horrible cant you restore them? or are they going to be replaced anyway...
M
Mike1
As mentioned in the original post, the pictures do not really highlight how ruined the lights are. They feel like extremely rough sand paper...
Jandre is planning on replacing them anyway so instead of buggering them up more I let them be.
missed that bit :fencelook: i knew that you would not have slipped up like that :rollsmile:
they look really bad with the paint so good now hopefully Jandre can change them soon :)
M
Mike1
You could wet sand them and probably get them back to normal, but I lack experience in that department and Jandre mentioned he had sourced another set.
I dont feel comfortable taking sand-paper to any part of a car. :fencelook:
freerider
Nice work there mike :thumbs:
As I said before Jandre, I'll help you with teh headlights, just need to get exams out the way first :(
M
Mike1
Thanks Don.
Really hating that Polish, I cannot get that stuff to break down properly yet the guys at Karismatic Auto can. :nonono:
The Pro Polish refined it very nicely though. :inlove:
Prev
Administrator
That car is looking bloody good now ....with the exception of the headlights. :bravo:
J
Jandre
I still haven't driven the car.
I just fitted the new viscous today, but other than that she hasn't seen the outside of the garage yet.
Reason for that is that it has been quite windy here for the last two days and I don't want my car to get dirty.
That being said, tomorrow morning she will assume the duty of becoming my daily drive.
Can't think of a better way than starting my week in my gleaming, clean new car.
Thanks Mike. She looks lovely.
And as mentioned, the lights are priority.
M
Mike1
Its an absolute pleasure, I really enjoyed working on her.
With the lights she will look perfect, still amazed by all the toys she has. :thumbs:
Oh, made this for you since you have sold POFS.
:rollsmile:
its not hard ive polished quite a bit of plastic, but it would be best to remove the lights so you dont risk damaging the paint around the lights...
I will also take quite alot of time to restore the lights so not worth it if they will be replaced any time soon...
I also assume that Jandre will fit the F/L lights which look way better than these :rollsmile:
Nic_s
Looks awesome. :thumb: I'm trying to get some good info on how to do a detail like this, or similar.
Now all we need are some picks of the E34 and E39 parked together :)
Legacy
I am currently in the process of becoming a detailing "amateur" and the biggest problem is the cost. You need about R5k worth of kit to do a full detail which includes some proper paint correction and interior protection.
As an example, the Menzerna trio which regarded among most as the best paint correction combo sets you back more than R1k for three polishes of 1 litre each.
This and some other facts makes Minimike's detail of R1500 (talking under correction of course) a MASSIVE bargain. :thumb:
