BMW E36 racing plugs **ngk b10egp**
rick540
If your engine is in good condition, you are already igniting and burning 99% of the fuel with your current plugs.
These things will make much more of a difference on a carb fed V8 where the fuel mixture is out of spec half the time. On a modern fuel injected closed loop lambda controlled, temparature compensated, adaptive fuel injection, where conditions are optimal all the time you are likely to feel no diference.
Just my two cents becaus I went through a phase a little while ago importing really expensive "racing" plugs and got zero result.
However if you want to play around with injectors, then you can have some fun
