Rish///M
Has anyone purchased one of these? How good is it? Is it worth purchasing?
See specs below - Website link:- http://cartools.co.za/oscommerce/pr...id=54&osCsid=3397dd2cd77894e8a8da45e7f1c4cce2
BMW CARSOFT Compatible interface
[BMW Carsoft] R1,999.00
Click to enlarge
BMW Vehicles 1988 - 2005
READ AND ERASE Error codes of various systems like DME, ABS, AIRBAGS, EGS, etc
RESET Service indicator light, Engine light, Airbag light, Traction control light, etc
RESET Adaptation values of DME and EGS (Automatic Transmission)
PROGRAM features like auto-doors lock on driving, selective locking
READ live data from DME / DDE / EGS
SYNCHRONIZE EWS and DME in case of a malfunction
Fully digital line switching and MCU controlled service reset timing.
Digital total test: Gives complete idea of the overall condition of the car
Digital single test: It gives you detailed information about the appropriate control unit. Stored errors will be shown in a written report. This report has a short info-text which help you in diagnosing the error.
Special functions for some models: Including service interval reset, component activation, live data, LCM reading, sync. EWS and ECU, adaptation values, coding, etc...
How it works?
Simply connect the device to your computer's serial port, select the correct cable for your vehicle (all cables included!), start the diagnostic program, and your computer will be able to communicate with your BMW! You will be able to perform two-way communication with your car, viewing and resetting trouble codes, service intervals, and much more! (see applications list).
VEHICLE APPLICATIONS LIST:
E30 / E31 / E32 / E34 / E36 / E38 / E39 / E46 / E53 / Z-3 / Z-8
Petrol Engines : ALL ENGINES from 1988 to 2004
Additional Features :
· LIVE DATA 1995-2004
· ECU CODING 1995-2004
· ADAPTATION 1995-2004
· EWS Synchronization 1995-2004
E30 / E34 / E36 / E38 /E39 / E46 / E53
Diesel Engines : ALL ENGINES from 1988 to 2004
· LIVE DATA 1998-2004
· ECU CODING 1998-2004
E30 / E31 / E32 / E34 / E36 / E38 /E39 / E46 / E53 / Z-3 / Z-8
Brake & Traction : ALL SYSTEMS from 1988 to 2004
AIRBAG : ALL AIRBAG SYSTEMS from 1988 to 2004
Air-conditioning : ALL HKL SYSTEMS from 1988 to 2004
BC / MID : BOARD COMPUTER / MULTI INFORMATION DISPLAY
INSTRUMENT CLUSTERS from 1991 to 2004
· ECU PROGRAMMING 1995-2004
· Change Mileage / Kilometres indication
· Change Time indication 24/12 hours scale
· Change Language indication into 9 different Languages
· Change Temperature indication Celsius / Fahrenheit
DWA : ALARM SYSTEMS
Including : ALARM ACTIVATION COUNTER E34
LCM / CCM : ALL LIGHT/CHECK CONTROL MODULES up to 2004
· Reading Original Mileage / Kilometres
· Reading CHASSIS ( VIN ) Number
EGS : ALL GEARBOX SYSTEMS from 1988 to 2004
EWS : ALL IMMOBILIZE SYSTEMS from 1995 to 2004
· SYNCHRONIZATION with ENGINE ECUs up to 2004
E38 / E39 / E46 / E53 / Z-8
CVM : SOFT TOP SYSTEMS to 2004 E46 (some E36 & Z3)
PDC : ALL PARK DISTANCE SYSTEMS from 1995 to 2004
Service Interval : ALL SERVICE SYSTEMS from 1988 to 2004
· Service Light RESET 1988-2004
· Service MANAGEMENT 1995-2004
· Reading of Days since last service
· Reading of Fuel Consumption since last service
· Programming of next Service / Inspection
Click to enlarge
How it works?
DWA : ALARM SYSTEMS
