kabal said:they cost about R400 or so
look for either myCarr CCFL or LED, depending which way you want to go, they are the best, and all the big "name" brands are just rebranded.
they are easy to fit yourself
gconry18 said:I was wondering about LED vs CCFL. I'm just worried that the LEDs are so bright that it does not look like a distinct ring from a distance.
moranor said:gconry18 said:I was wondering about LED vs CCFL. I'm just worried that the LEDs are so bright that it does not look like a distinct ring from a distance.
some cheap led rings look like that mine out look solid like ccfl ones i would not even thing about ccfl the over heat very easily
no one that makes decent angles use ccfl anymore because of that leds are brighter use less energy and last longer ccfl is rubbish
kabal said:moranor said:gconry18 said:I was wondering about LED vs CCFL. I'm just worried that the LEDs are so bright that it does not look like a distinct ring from a distance.
a bit harshwouldnt say CCFL is rubbish, its just that technology has moved on. IC and SMD's get cheaper to produce, reliability goes up, its progress.
this is like saying that LCD tvs/monitors are rubbish, you must have an LED monitorimp:
BTW, I will be putting my AE's in the FS section soon
