BMW and Mini ECU repairs
Ratslaaf
Hey gents,
As some of you have guessed, I've been spending a lot of time lately repairing the ECU's from BMW and Mini cars.
Now, it should be noted that I'm not simply swapping ECU's like most of the guys out there are doing, I'm going down to board level to fix these. This allows me to be very competitive, as much as 50% less than the cheapest guys out there.
Each repair is handled on a case by case basis and if you are local to me, it involves my assistance in diagnosing that the ECU is actually the culprit and if so, to have it repaired professionally and tested IN YOUR CAR! All your Vin's and ISN's remain intact and you're not forced to replace the CAS and keys for your car.
In some cases an ECU cannot be repaired, especially units that have been water damaged. These are a little more problematic but in many cases I can supply a replacement ECU that is then married to your car.
So, give me a call if you get stuck and I'll do my best to get you back on the road without expecting a months' worth of pay for the service :=):
