Bmw 530d E60... Not Starting... Help
yoginn
Water in the electronics (spare wheel compartment) is a known culprit for the battery drain issue.
curious to know the actual problem with the cam sensor and what the leak-down rate of the leaking injector was.
Sportpack
Have you sorted out the battery draining issue? I had that also. Turns out that I had one too many tracking devices in the car. You need to get the ones you dont need out asap.
.FOURTY-5
Hi guys sorry for long response... the reason why it was not starting was fuel pump... that was changed and i fitted a new battery... but now the battery drains overnight... what could be the problem..
