Dean ///M
Limited Profile
Gents, I need some help regarding the dampers/struts offered in this Perf.suspension package. #33 50 0 444 831. Is the stock dampers on my 135i (M Sport suspension..as std) not the same as the performance dampers. I checked out the parts numbers & they are different. But what brings about doubt is that the sway bar is the same diameter as stock 26.5mm. Also with the Perf. Brake kit it's the exact same caliper used just sprayed in another colour. Cos if the dampers are the same then I will only order the Perf. springs...will save me alot of money...
