Best product to de-contaminate oil contaminated coolant - bust oil cooler
anton-sa
As in subject, my 2000 530d recently broke a oil cooler, so one evening out in cape town it was like 12c out and i started overheading while doing about 140km/hr...
weird.. thats never happened to me before in summer, let alone winter.
first thing i thought was "water pump has packed up".. so i stopped the car let it cool off (temp only went to 3/4 on the gauge)... drove on... repeat... repeat.
1.5hrs later i got to a friends place (alot closer than my house) where i left the car overnight, had it towed the next day to workshop...
it ended up being the oil cooler that went bust and sent 80% of my engine oil into the coolant.
what a mess, several radiator flushes later its mostly sorted, but now ive been doing some research to find a product that is best suited for this job, as in a week or so's time i want to give another flush just to be sure.
According to my research, the best coolant cleaner money can buy is made
by a company called fleetguard (cummins diesel), its called
RESTORE + RESTORE plus
http://www.cumminsfiltration.com/html/en/products/cooling/system_cleaners.html
now the RESTORE plus (available in africa and south africa) is a general coolant cleaner. the product which is listed for cleaning oil out of coolant is Just RESTORE, but its not available in sa or africa.
here is from the website:
Restore
Alkaline-Based Cleaner
Most Effective Cooling System Oil/Fuel Contamination-Cleaning Agent on Market
Removes Silicate Gel
10 Times More Effective than Automotive Distributor Detergent Powders
Safe for Use in Aluminum Radiators and Heaters
Restore Plus
Mild Acid-Based Chelating Cleaner
Safely Removes Rust, Corrosion, Scale, and Solder Bloom - Without Disassembling your Cooling System
so can be seen, i actually would really benefit from the "Restore" product.
does anyone else know of anything else? thats actually available in SA ?
some say use some dishwasher detergant for the flush... but i dunno..
any tips from those that know of a product or someone who has had to deal with this scenario before would be appreciated..
thx
Anton
