Be aware!!!
Wick-ed
"IF YOU ARE DRIVING AT NIGHT AND EGGS ARE THROWN AT YOUR WINDSCREEN, DO NOT STOP TO CHECK THE CAR, DO NOT OPERATE THE WIPER AND DO NOT SPRAY ANY WATER BECAUSE EGGS MIXEDWITH WATER BECOME MILKY AND BLOCK YOUR VISION UP TO 92.5%, AND YOU ARE THEN FORCED TO STOP BESIDE THE ROAD AND BECOME A VICTIM OF THESE CRIMINALS. THIS IS A NEW TECHNIQUE USED BY GANGS. Please pass on. :thumbs:
L~C~G
Thanks for the heads up.
These things have nothing but time. They sit all day with their fingers up their asses dreaming up crap like this.
I wonder what they would like first: Pepper spray.......................knife............................9mm hollow points! MOTHER F*CKERS!!!
Caddy101
Damn, these motherf#ckers are innovative, F#CK!!!
Remote jamming, eggs on the windscreen...
Is it possible to get a sawed-off shot gun, with hollow points?
That Desert Eagle .50 thing, how much do they go for nowadays?
L~C~G
Never seen a hollow point for a shottie but you get a nice little thing called a solid slug! OMFG no one is getting up after taking one of those. Im actually looking for a semi-auto shottie for protection against a home invasion and it will have slugs in it.
Desert eagle is a serious over kill and rather heavy. a .357 mag with hollows will do just fine.
Philip Foglar
This is a relatively old (well in recent years) trick, so yes, if something appears to have been deliberately thrown onto your windscreen, do not use your wipers and washer to attempt to clear the windscreen - this will just render your windscreen useless to see out of forcing you to stop at which point you will most likely be hijacked/robbed!
UpNcOmiNg!
Events Organiser
mmmm, 9mm glock with a clip of black talons!:inlove::inlove:
Hello nurse................quite literally, for them. Hmmm, Morgue rather actually.
These thieving bunch of thug bastards deserve to get a hiding.
L~C~G
gconry18 said:
This is right up there with the steel pipe in the road trick.
At least you can retrieve the pipe and serve up a beating with it. Eggs are useless.
They must have given up on pipes because of the cash for scrap steel price, the pipe would get scaled before a car even hit it.
Good luck finding those in S.A
