Update:
After replacing the fuel filter, the starting issue is still there, It still takes about 3 to 4 turns before it starts up , This only happens after the cars been sitting for a while , though I noticed if I press the acc down, the car starts up quicker.
If I switch it off and after staring it with the issue, the first time and restart it , it will start almost instantly. And it does this all the time thereafter. Its only after its been parked for a while does it give a problem.
Replacing the filter has helped with drive ability , all the previous issues seem to have gone now. Engine is smooth at idle , stopped in traffic its fine, no rough engine. So it wasn't waste replacing the filter. Surprisingly though the old filter wasn't that old, I replaced the original that was on the car from new with this one last year , and had done just a few thousand Kms with it. This was a Bosch filter.
I decided to take the old fuel pump apart . Tested it before taking it apart and it wouldn't spin, So took it apart to see if there was anything in it. It was pretty clean, no dirt or damage. I checked for wear and it didn't seem worn out at all everything looked pretty newish. This is the original fuel pump that was on the car from new. I did find some white, dusty thin layer of sediment on some of the parts... What could this be? It was on the plastic mesh filter as well. Iv cleaned up all the pieces and will reassemble it to see if it works after the clean.
I didn't have time to have the fuel pressure tested on the car, this load shedding is killing me, everything gets delayed by at least 3 hours each day because of it.
When testing the old fuel pump previously (non start issue) , While using a test light , I noticed that the pump will only get power (that is my test light will only flash) when the engine turns over. Unlike my E30 when put into ignition position two which primes the lines , the light wont come on and I don't hear it buzzing.
On the E46 N42 , should it also prime at position two before turning over? Mine seems to only "pump" when the engine turns, Is this normal?
francoishensen11 said:
Yeah I think it should be around 3.5 bar, with the correct fuel pressure tester connected,put ignition on as the pump primes you should get a reading of about/close to 3.5 bar then put ignition off,leave tester connected for about 10mins and check what the pressure reading is, if there's a significant drop on the gauge you have a possible leaky injector or the built in valve(check valve I think the yanks call it) of the fuel pump is messing about
Sent from my GT-I9505 using Tapatalk
