Ambient lighting
Good day forum
Where can one retro fit ambient lighting on an F30 in Cape Town?
Sent from my MAR-LX1M using Tapatalk
Iceman007
My 320d did not have ambient lighting but my 330d does it even has the lights on the outside handel and when you open the door it has the logo projectors in the bottom of the doors. So in short the door pannel trimmings are different and also you will require wiing to all doors. Also you can adjust the ambient bightness and color on the idrive. Not sure but I hink that retrofit will cost you a pritty penny.
Only thing I changed on ambient light is that I coded the brigtness adjustment is seperate from the dash brightness. And fitted some plastic strips in the door so that it shows a slight line in the dark like the 5 series
So I managed to find a guy in cpt who does led under lights and door strips, the under lights look good door strips are so so
Iceman007
Door strips is a bit to much. Can you adjust brightness?. Might be a bit distracting when driving in the dark
On the under lights yes and change colour door strips is currently one colour but I'm having those removed soon when he gets better stock
