Cray
Ok so I'm gonna ask the question and answer it :clapper: But was just hoping if someone had this before and/or could it be something ells wrong rather then the expensive part BMW says it is....I know, I know just trying to see and understand the problem better and if its common????
So 3 weeks ago went to the shop 800m from home, on my way back this happens.
Airbag Red Light, Car on Lift red light, ABS yellow, Traction yellow, ! red...one or two more cant remember. The speedometer, rev counter not working. Back light off. Flickers and hazards not working, electric windows not working, aircon not working, door lock button not working, key FOB to lock and unlock not working.....but hey the car drives perfectly fine.
At home I wanted to disconnect battery (like very clever google says), but I cant open boot, no key hole. So after crawling through the back seats and pulling hatch inside, I disconnected the battery like 20 min and connected again and bang all fine....for a week.
After doing the procedure a second time, all lights off and the only thing not working is my flickers, hazards, electric front windows. Took the car for diagnostic at BMW and they told me the following.
My control unit went and will cost 8k to be replaced. I tried to get more info, but thats about it. On the quote it says "Footwell Module"
On the diagnostic report it says the following and I quote...
"windows not working correctly. connect isid and batterychaerger. do quick test. work through test scheduel. found vehicle storing frm module fault. check voltagesupply. check fuses. vehicle storing no communication fault with frm. check lines and plug connections betweenfrm and gateway frm faulty and needs to be replaced." (I quoted exactly
What is FRM...controll unit. I took my car to battery centre and they did a load test and it tested in the red?
Today all the lights came on again....seems like once a week...
Anyway...just thought I'd supply my experience with this electrical problem I'm facing at the moment, dont have 8k lying around now. Off the record they said I can drive like this as it should cause my car to die on me....oi oi oi
