airflow meter
Magic stick
hi guys...need advice please...i have a e36 316i...how do i knw if my airflow meter is buggerd.....my car dnt idle straight..it idles up an down.... My tail pieces burn black an da fuel smell abit rich....wen i pull i see sum smoke an it smell rich at da back...can the air an fuel mixture be out .....can a person set it by da side screw on the airflow meter?....thanx
Die_Miek
you can start by having your codes read.
if you wanna test the maf, disconnect it and drive it for a week. if the car drives better you know its klaar.
symptoms you describe could also be a vacuum leak
