Bradford said:
Took it for the diagnostics and no errors relating to the aircon or electrical system were found.
The aircon did initially blow cold air, but after switching off the car and restarting - no cold air.
This happened initially after refilling and again after the diagnostics.
It seems the compressor might be the problem, and I'm told the compressor does not have a clutch but rather valves that become screwy.
Anyone know of a reputable aircon place that might recon the compressor without ripping me off in PTA?
The valves are in the piping, not the compressor.
Modern aircons work a bit differently than those of earlier years. The compressor is always pumping, whether the ac is on or off, but the pressure release valve is open when there is no request for AC. This means that the compressor will pump with no resistance, but will still be well lubricated at all times. This actually increases compressor life expectancy when compared to a clutching system.
One side effect of this is that if the compressor does fail, it will slip on the belt, where previously it slipped on the clutch. This could cause the belt to fail and a lot more problems than before. So now they modified the coupling in the compressor so that it can break when the compressor is pumping harder than the maximum design specs.
So you have three possibilities:
1. The guy who filled your gas last time used the wrong amount of gas or wrong amount or lubricant or did not purge the lubricant from the system, causing the compressor's weak coupling to fail.
2. Same as above, but the system detects an incorrect pressure and does not engage aircon.
3. The release valve failed.
Hopefully somebody else on here can help you out with a good AC specialist.
