Airbag light help needed?
Adi
So I was driving yesterday, and my airbag light came on, how can I fix this?
Hope eveybody has a fun start to their Monday!
zaleonardz
Bud,
Your not seeing the obvious here, have you checked the ashtray light, cause clearly its that whats causing the problem ....
(If thats ADS I can help turn off the light btw)
Sankekur
zaleonardz@DentDoctor said:
Bud,
Dude I want what you are smoking, this is obviously a shift linkage bush related issue.
zaleonardz
Do you think so ....
I mean, look at the temp gauge, its not right in the middle, ashtray lights cause that, im sure...
Sankekur
Don't know where you get that from, the temp not in the middle is definitely a gearbox issue.
A faulty ashtray light causes the fuel gauge to be non-responsive, everyone knows that.
J
Jandre
Software will not fix this.
You will need hardware. may I recommend some black insulation tape. A square about 15mm x 15mm.
It's a DIY, so you save huge on labour charges.
:thumbdo:
