There are 2 seals around the oil filter housing, one under the housing, one on the side where a cooler or heater of sorts is attached, these seals perish over time and cause an oil leal, this oil then drips onto the alternator, and if not attended to, destroys thye alternator, as happened to my daughter's car, this alternator is CRAZY expensive from BMW, R12k, aftermarket ones are available for under R5k, or even cheaper from a scrapyard, BUT, for about R170.00 in gasket prices, you can save yourself some heartache and moolah. I'm told these seals/gaskets should be changed every 60 000km....so, change them at your next oil change, they are easy to do.
