Chucky said:... she drives a e90 320i.
Skwinty said:See this link for the NAAMSA database for model specific fuel recommendations.
http://www.naamsa.co.za/unleaded/databases/index.php
Chucky said:Shot Skwinty
but those are recommendations and does not really say if there are any advantages to using either 93 or 95 octane.
P1000 said:Nope. Octane requirements gets derated as you go up in altitude.
That said, getting an exact number is not as easy, as it seems to be engine-dependent, and our fuel in SA is not exactly the octane they say it is. But if you go and do the calculations, your car is far in the safe-zone on our 93 on the reef, since the BMEP gets reduced by around 14.5% in PTA/JHB.
If you really want to know if you gain anything by using 95, you need to see the spark adjustment values of the ECU. I'm unsure if you can do so in INPA/DIS, but it would be interesting.
The reason that turbo cars need higher octane up here is because their manifold air pressure is less affected by altitude - and consequently BMEP, since it is electronically regulated.
Fordkoppie said:What you say is 100%, but most NA petrol BMW engines are fairly high compression motors.
Higher octane does sweet blue bugger all for performance, but if the knock sensors detect any detonation, it will retard the ignition timing and therefore you lose power as you already know.
Increased octane just aids in preventing pinking since spontaneous combustion gets suppressed more.
I surely won’t put in anything except the highest octane I can get for the M3, because I can really feel how it retards the timing (after hearing a short burst of pinking) with lesser grade fuels. I have tried this numerous times, since I have to go up a very steep and long hill when I just start driving (from cold) at work. Trying to keep the RPMs low since the motor is still cold, and with the high load, this “surging†is very pronounced as it starts pinking; retarding timing; then upping the timing again; pinking; retarding…. etc.
The M3 has a compression ratio of 11.5:1
Ephraimramodike said:Since we know that there's no diff in performance... Does your engine last longer if using 95 for a N/A engine? Or would there be any mechanical problems in the lifespan of the engine?
If not... then clearly there's point in spending extra cents per litre for 95 if you have a N/A engine... right?:thinking:
Skwinty said:If I was to live on the reef, I would use the recommended petrol. :fencelook:
