ABS LIGHT STAYS ON!
Donavan
My ABS light on my 95 e36 325i droptop stays on,does ne1 know how to take it out just until i fix it? .i need that light to dissapear coz im taking it for c.o.r . . . and well widout me goin to the agents that is:hammerhead:
freerider
might just need a reset in the ECU, could also be that one of your tyres is under inflated, just check all tyre pressures as a first measure
EDIT: pop in to Zeemax in paarden eiland, and speak to Zaid about it, he might even just plug it in and reset it for you ;)
Donavan
sharp rider i also think it just needs to be reset but just to do that at BMW agents will cost me an arm and a leg!
freerider
I'm telling you man, pop in at Zaid and tell him what its doing.... He has often just plugged my car in and reset stuff for me at no charge. There service is also tip top.
Donavan
Il check da relays in the fuse box and also da fuses.bt 1st need 2 find out which fuse is 4 wat. . .bt i temporarily fixed the prob so i can take it 4 c.o.r ,i jus pulled the dash out and unscrewed the bulb....tada no mre abs light lol!
SirSparky
mine came on sometimes and went away till oneday it stayed on....the cheapes and first route i followed was to change the relays
Donavan
yeah i think myn is at that point were it stays on.i took it to bmw agents but they said that they wud need to check the continuity of circuit and thats a 3hour job at R495 an hour!.and thats without solving the problem
kabal
I have a problem where mine sometimes comes on. I can turn the car off and then back on and it will go away, so in my case it is probably a bit dirty.
I do however have and issue that my pad wear light is permenantly on. I changed all my pads about 3 months ago, and it started about 2 months ago.
freerider
They probably put the pad wear sensor back in incorrectly, or maybe the wire has sheared somewhere inside the wheel arch.
kabal
I changed it all myself, I think I remember replacing the sensors :p
it only started like a month later, so you are right, it probably came loose or broke
