Hi all, new to the forums here
My climate control unit (if that is what it's called) is on the frits again.
What will be my best option here? Replace it, get it fixed, can I do it myself?
Then my headlights don't come on any more, the high beams work fine. The computer isn't telling me to check the lamps. And I did check them, they are fine. Someone suggested the relays, now I’m not sure if i checked the right stuff, but in the same place you find your fuses (yes i check those as well
) there are these larger block thingies, I managed to find the one that goes click when i turn on the high beams (so I’m guessing it works) and swapped it with the one I think is supposed to control the low beams. Same result, the high beams work but no low beams. Question is, are those the relays that I tested? Then if it isn't the relays what could it be? The switch itself? but then which switch, the round one on the right side or the one in the steering column?
That is all for now
and thanks in advance.
That is all for now
