discussion 340000km m44! Time to replace?
Smell my finger
Hi guys. I have an e36 318is with an m44 in it. The engine has over 340000km on it and has been giving me problems on problems lately. This engine has seen some stuff even before I got my grubby little hands on it. I'm continuously discovering stripped bolts and white spots on black plastic. I think she's been overheated before and maybe even rebuilt. This would mean my rebuild is the 2nd in its life. At what km do people usually replace these motors and why. I just want it to be as reliable as it used to be😭
Should I bite the bullet and get a import or just scratch the itches on this 1?
Smell my finger
What are the issues. I mean if you expect someone to give a meaningful answer one should provide information.
Fair. Rear main seal bad leak(replaced), timing chain tensioner weak(replaced), rings cylinder 3( replaced all + head gasket+big end bearings) 10k km later blue smoke, replaced valve stem seals smoke went away but lifters started ticking loud next jobs: lifters, timing chain and guides, fuel injectors, replace all the main vacuum hoses as they are eroded and helicoiling 6 stripped holes for the timing chain cover and valve cover. I've calculated and by the end of it, using quality parts, it's about R2000 off what an import motor is gonna cost
Gordvisr
A proper rebuilt, checking clearances and maybe resizing of some parts( pistons, rebore, resizing of connecting rods\new conrods ) i believe you can keep the original motor.
tamgoem
Import motor is a unknown, it can be good it can be bad, but remember once that import motor is in and it has issues like say a leaky rear main seal the cost benefit swings to rebuild.
Reading that it sounds like the motor is due a topend rebuild and probably the rotating assembly needs to be done (New pistons etc) it might just be cheaper to dump the car and get a 6cyl E36 or move to a E46 M52/54
Smell my finger
I was thinking about that. maybe boring it out to 2lt and going full btcc spec with throttles and such. I dont know we'll see doing a full check tonight. Compression test, leakdown and look at the pistons with a borescope.
Smell my finger
Nah this car is quite special to me too many memories. Maybe I start pulling it apart this weekend to see if there's anything horrible going on and maybe then it'll be clear what to do😢
Smell my finger
Just discovered I never updated this thread. Finally got some time to dive into the bay of the 36 and removed the whole motor, tore it down discovered discolorations in the cylinder walls and light gauges on cyl 3. Sent the block away for a bore. Builder said last guy that did a 2L bore on this block is having heat issues and advised to go 20 thou as it's more reliable. Pistons will now be 85.5mm. Couldn't find Mahle or Kolbenshcmidt pistons so I was forced to go with ARCO(Alert engine parts in-house brand) and accompanying rings builder said they'll be alright. Otherwise new conrod bolts, crank and big end bearings, welsh plugs and all new gaskets. Also discovered a smashed dowel on the crank no damage to the crank itself though. Decking the block as well. Next up is headwork. Planning a port & flow, 278/264 cams and itb's but for now we wait🙃
Greenz
Glad you making progress with it.What itbs are you thinking of getting?Are you down at the coast?
Smell my finger
Was thinking of importing the ones made by RHD in the US they have the carbon plenum and all the flow dynamics are scientifically proven. They're extremely expensive though so if anything else pops up I'll have a look. Car is down in Durban
Smell my finger
Update: I'm stuck at pistons. The pistons sourced were completely wrong on arrival. Somehow I received n13 pistons and supplier(Alert) could not find a good quality replacement. I'm now in a hole where I have to order pistons from sweden(Mahle brand). It's much more expensive than planned but I guess quality over quantity is my justification. Does anyone know of anyone that could possibly find good quality pistons NOT FPR🤦🏻 in SA?
Greenz
What's the damage for those pistons with shipping etc?
