335i Tuning
///Avi
francoisellis28 said:
Howzit, was wondering who do you guys think does the best tuning in Gauteng.
Load off the shelf maps with mhd. These aren't going to get as much out of your car as a custom tune but does quite a good job.
I would also suggest using a Jb4, and stack it with the mhd back end flash. Allows map switching with jb4 and timing/fueling is controlled by the ecu. Benefit of a flash tune with the flexibility of the jb4.
If you are chasing big power, with inlets for example, you probably should get a tuner involved. Many of the "tuners" in SA will probably send your logs to an actual tuner in the USA to write you a file anyway, so rather go with experienced shops who use good tuners from overseas with proven cars in SA. I wouldn't know who to recommend though.
