phantom said:
Ok so 7000km later and sanity has prevailed. Some more observation.
My fuel consumption on the car used to be an incredible mid 4 litres per 100km.After the PPK you struggle to get high 5.
After getting my new F30 335i I now see what the problem is.On the standard ECU when you take your foot of the accelerator your revs fall to idle status as if the gearbox has been disengaged.This function is only on ECO PRO.
I went to the dealer yesterday and we took a F30 330d off the floor to test that this function is on the diesel car as well as on the 335i.
The function is there.We then proceeded to load all the updates from BMW onto my car but to no avail.Therefore the software on the PPK ECU to my mind is a botchup.Why not still have the economy on the ECO PRO and just up the power on the sport and sport + then you have the best of both worlds?
Fuel consumption is a major part when people consider a daily vehicle
as it comes into play all the time.The more power from the PPK kit is something you may enjoy 10% of the time.
Based on this info i cannot recommend this kit until they fix up their software and am probably going to put my standaed ECU back into the car.
Expensive exercise but at least the brakes and bigger intercooler are not wasted.
Ok so if I understand you correctly the rpm drops to idle, my car defnetly does not do this in Eco pro mode or any mode, It does feel like it coast, but the rpm stay the same , even goes higher on steep down hills at any speed from 60 to 140kph.
