328i Individual without Sports Seats
splintheter
Evening All,
Is there any reason why a 328i Individual wouldnt have sports seats?
everything else on the car suggests its a genuine individual.
- side beading with ///M on it
- front spoiler
- rear splitter
- 150kw engine as per Bmwvin.com
just find it odd there is no sports seats ?
Thoughts ??
Just double checked it also has anthracite roof lining, which really must make it an individual....
splintheter
Nikhil said:
150kw? Isnt it 142kw?
apparently the Individuals had 150kw to help drag that extra body kit around, I also just found this out.
Picture courtesy of Moose :)
rodga
You can use a vin decoder to see the options specced from the factory. It might have been specced with normal seats? Stranger things have happened
Sent from my SM-N900 using Tapatalk
splintheter
above photo is all the vin decoder spits out.
444YYY
The locally assembled cars with the vin number starting with "A" have little info on vin decoder! I know it's says Munich, but it was probably a semi-knocked down kit... The vins with W have more info!
pi328
Wheels have been tampered with too, as the Individual came with contours, not the M wheels. The front indicators were orange back then. And as you mentioned already, there was no M badge on the kidneys.
Maljan
The 142kW power output was more of a marketing limit than an engineering limit. It corresponded to a big jump in taxation in the German market. There was always more power in the M52 than just 142kW.
rodga
In 96? I think clears were available already
Nikhil
Wasnt late 96 facelift so it should have different kidneys and the smaller type indicators on the fender? Then it would be clears all around. Something seems off.
splintheter
Car only has front clears. He changed them when he hit a bird on the N7 and it smashed the original.
WyKiD
Rear wheel look to be a narrow one can't see the lip. Should usually be fitted with contours. Car looks clean though....
Fordkoppie
Those appear to be reps. Shape of the spokes are wrong.
All narrow
splintheter
All narrow
Yeh they are reps. He replaced them as he didnt like the calypso's (neither do I) but he is giving me the originals with the car.
Going to try find a set of style 32s :)
Ok, so I got hold of the Selling Dealer (Forsdicks) original build was that standard seats were specced with car. Original owner was apparently in his 70s :) :)
