E30 325is evo 1 and evo 2 summarized specs
In South Africa we didn't receive the E30 M3, instead we got the325iS , Evo 1 and Ev0 2, which where locally build.The 333i was also a South African built car, with a 3.3L engine of the 733i
The 325is Ev0 1, was a 145kW 2.7 straight 6here are some spec's. These cars are collectors items now the price range is between 9000 $ (us) up to 19 000 $ (us)
EVO aluminum, bonnet and boot lid
2.7lt motor same pistons as Alpina B3 2.7
Head was same as 2.5,with revised larger valves,
alpina 276 cam
Uberko Cloth or leather interior / leather
Sunroof optional
Available in Black, Red, Silver and White. Some were made in Blue but very few
M3 E30 Suspension 5 Hole wheels BBS
M-Tech 2 Body Kit
145 Kw Motor
LSD
top speed 236kph
0-100 in 7.2 seconds
Later on in 91-92 the 325iS Evo 2 was produced
here are some EVO II spec's
Steel body panels
Larger roll bars
Lower Springs 15mm in front 10 mm at rear
Limited Slip Diff
535 Air Flow Meter
Alpina Spec Head
Leather Interior
Front Aero Lip with under tray
Branch Exhaust system developed by Alpina276 Camshafts
Rougher Idle
Recaro seats,Bilstein suspension
155 kw motor.
The Evo 2 was not faster than the Ev01, was the mid range was much stronger through the rev range,
top was 237 kph
alpina 276 cam
Sunroof optional
M-Tech 2 Body Kit
145 Kw Motor
LSD
top speed 236kph
Steel body panels
Larger roll bars
Limited Slip Diff
535 Air Flow Meter
Alpina Spec Head
Leather Interior
Rougher Idle
155 kw motor.
top was 237 kph
