Hi all
I have a problem with my 323ci.in the morning my car starts fine.when i reach work an switch off an start again its takes abit long to crank an there is a power loss cuts out in the drive.after few ours after it cools down an the temperature gauge is in the cool mark its starts normal an the power is again an till i switch off an start again she goes back to that mode.i had it on the auto logic an code showing it was the inlet camshaft sensor.i fitted a camshaft senor an still the same.could the sensor be faulty?i had the services done too still the same.
Any feedback would be appreciated
Thank you
Sedick
Thank you
Sedick
