Bmwed said:Morning gents.
Please help.. I have oil in my water bottle but no water in my oil. Is this the head gasket or typically what would this be![]()
Bmwed said:i replaced just the cooler. You think there might be something internally faulty
Sorry i just replaced the gasket not the cooler
Tjoppies said:phew , thats going to take some cleaning effort. :dunnoanymore:
good luck.
Bmwed said:Thank you very much for the help. Would you guys use a degreaser in the cooling system? Just to help get all the thick sludge out?
rudolphc83 said:Bmwed said:Thank you very much for the help. Would you guys use a degreaser in the cooling system? Just to help get all the thick sludge out?
I used Prepsol (Engine degreaser) with very good result. Prepsol is a well known name though. I would be careful to use just any degreaser, some may contain chemicals that could potentially damage some of the seals in the coolant system. Prepsol did the trick for me. Still takes a bit of effort though. You need to flush a couple of times until you don't see any oil coming out when draining the system.
NtandoN said:rudolphc83 said:Bmwed said:Thank you very much for the help. Would you guys use a degreaser in the cooling system? Just to help get all the thick sludge out?
:withStu:
Took ten or so flushes over a period of a week and replacing the coolant reservoir to get it to acceptable levels.
When using prepsol be careful not to keep in the cooling system for too long as it ca damage seals.
