320D
theking
HI GUY'S
hope someone can help me i came down to durban for the top gear festival and my car started losing power and smokes black like crazy i am staying in amanzimtoti and took it to bosch but they took the whole day telling me they don't know what is wrong but suspect it could be injectors cylinder 2 and 4 is running verry lean can anyone dircet me somewhere to someone who can help me wich isn't going to cost me an arm and a leg
had the turbo done few months ago so defenitely not the turbo and the crank case breather valve is also fine
please guy's whould realy appreciate your help i am desperate must be going back monday
Twinz
Forum - Support
Welcome to the forum. It is a terrible thing to be stuck so far from home. The problem you describe does not sound like a quick fix and workshops are closed on a Sunday. Even if you do find a reasonable priced workshop tomorrow the car will have to be checked in for repairs which will be a couple of days. You may have to consider making alternative arrangements to extend your stay in Durbs or for the car to be trailed back to Lichtenberg.
All the best. :thumbs:
netercol
BLACK smoke means incomplete combustion.. which means either overfueling( too much fuel ) or too little air (boost problem)
boost pipes leak, intercooler leak, turbo actuator malfunction, turbo failure would all cause no boost or low boost ( too little air)
fuelpressure control solinoid , ect might cause overfueling .. but im leaning towards boost problems.. just because your turbo was done a few months ago does not mean it cant be your turbo..
tell us more about your model and year..
Dhp507
plus one ..............
D
Dippies
+ 2
Dhp507
+ 2
If you still in Durbs - Give The Agents a call and speak to Macho. Tell him Yegen sent you green, E46 Mp plates
THE AGENTS. 031 312 6707.
Let us how know how it progresess
theking
hi guy's
i am back home got back yesterday and car is driving like a dream again
thanks netercol you were spot on it was a boost pipe and if any of you are ever stuck in durban look this place up glazertech he specializes in only bmw's and
defenitely knows his stuff
the king
