320d G20 - Carbon clean and software
yasirm
Hi Guys,
I have a 2021 320d G20, looking at doing a carbon clean and software.
Which place would be the best to get this done?
Xcede Performance
If your ecu is manufacture date is >June 2020 the ecu needs to go to Femto Evo in Finland to be unlocked before we can tune it.
lebofa
Hi Guys,
out of interest, why do you want to do carbon clean? My F30 320d is over 11 years old and still going strong with no signs that it needs carbon clean. Just curious to know the telltale signs to look out for
Kyle
You will see why if you ever look at the EGR valve... Always best to clean all the 'carbon' off after deactivating EGR via software...
lebofa
I was hoping for a response that doesn't require me to strip the car. I stand to be corrected, if EGR is blocked or has an issue, there will be a warning or an error pointing to the fact. There will be other signs telling you that you have an issue, high fuel consumption and loss of power maybe? I highly doubt a 2021 diesel car will have too much carbon build up to worry about. As I said, mine is over 11 years and I have not picked up any issue yet. @yasirm, if it aint broken, don't fix it. What is the mileage of your car? Rather get someone who can assist with borescope and check your combustion chambers to see if there is any carbon build up.
Kyle
Ok man..
yasirm
I previously had an issue with carbon build up on a 330d I had which costed me lots of money to sort out, so was just thinking of maybe doing a carbon clean on this car.
K_S
Will PM you the details of an innovative new carbon cleaning company - and will also ask the founder/owner of the company to contact the admins and consider posting here to explain how the cleaning process works.
NBN
Have you tried reaching out to Marchand at the carbon doctor if you are Jhb based?
Scotty88
I doubt in 5 years it would need to be cleaned . Rather do software and egr delete with blank plates.
Sent from my SM-S928B using Tapatalk
mosome
Hi Guys,
I just completed a carbon clean last week on my 9yr old 140kkm mileage X5 F15 M50D (N57S) with Carbon Doctor in Constantia Kloof. I did the carbon clean because I had a problem with swirl flap mechanism which is a result of carbon buildup in these engines and this particular engine (tri-tubo) is very sensitive to any small malfunction. I have before and after pictures of the various affected components; intake ports, intake manifold, throttle body, etc. They were quite bad but I have seen worst at similar mileage.
I have two other 14yo 2.0D (f10 & f25) with 260kkm & 314kkm mileage and they have no sign of needing a carbon clean. Unless the car suffers from poor performance and higher fuel consumption I would not recommend a carbon clean as it has negligible benefit on the one turbo diesel engines without DPF, in my view. Does your car have DPF?
Camagu
How many kilometers on the clock and is it stock with dpf and egr valves without any tunning or software?Just curious bcos my g20 320d is @66k km and use sasol 10ppm and wyns Diesel n turbo sometimes n I wonder if I can get to over 300k km If I don't do any software dpf n egr valves delete
lebofa
The car is stock, has BMW MPPK from new and now sitting at 180k km. I also use sasol 10ppm only and no additives
