Hi all
I hope I've chosen the correct forum - I need some info on generic clutches for my vehicle.
The problem with the car is this: when depressing or releasing the clutch there is a grinding noise. It's not there while in gear or out of gear, though, only when engaging or releasing. There is also a slight shudder when taking off in 1st gear.
According to one mechanic, there are no generic clutches for my 320D E90, and I should expect to pay at least R20k (includes labour). But he says I can still drive it for a good while before I get any real problems.
Another tells me total clutch failure is imminent, and that he may have a generic flywheel but he'll have to check if it's the same first. R7350 for the generic flywheel and clutch kit, otherwise R15k for the BMW flywheel plus another R3150 for a generic clutch. He tells me the thrust bearing (not sure if I heard right...?) is gone.
These two stories are different enough for me to wonder what the true answer is. Does anyone have any info for me, or can help me out?
Any help much appreciated!
James
James
