320d e90 Error Codes
Hi Guys
My car is due for a oil service in 4700km , so I took my key to get a reading at Bmw to see if there is anything else needed and this is what came out.
Under Faults: NO ENTRIES AVAILABLE
There are 4 other fault codes for which no PUMA measure could be found: 9C53, 5DE2, 5DEC, A670
The last major thing I did was replace the 4 break pads and sensors about 3 months ago.
Lizzard
So when bmw did the key thing they came up with those 4 codes, correct.
BMW itself record and save the error's that the car had when you take it to them for service or repair and that is what might have happened here. So I wouldn't worry too much about this. Maybe get the car itself to someone with diagnostics to read the car and see if these error's has been cleared and if they are not returning.
Also if the car gets a hiccup it registers error codes which has nothing to do with anything but because at that stage it had a bit of a mishap it registers error codes.
Best would be to clear the error's and then see in a week if they return and then worry about them. Those 4 codes is different Areas in the car.
5DE2 - is for your sensor that went on your brakes which you have replaced :rollsmile:
