320d Airbag warning light
schuttec
Hi all
The airbag warning light on my 320d has come on and is quite annoying. It came on a few months ago and I had it cleared when I serviced the vehicle. I am aware that it could be a real fault with the airbag system, but I am also aware that this is a "regular" problem or "bug".
Is there any way one can reset or bypass without employing diagnostic tools?
Thanks.
Chris.
zaleonardz
Most likely a bad connection on the front drivers seat,
Remember your SRS system is not just airbags, its seatbelt pre-tentioners ect.
Over time the connection on the seats degrade, usually drivers considering use.
Read the error, figure out where your problem is and fix it.
No you cannot bypass/clear without diagnostics.
Yes there are methods/ways to bypass and even disable, but rather just fix the wiring fault.
Ralf*
the "dreaded" connector under the drivers seat, knocked about by the vacum cleaner
been there a few times already
