318ti window switch
Rasmoes
Hi
Hope somebody can help. window switch on 318ti broke (driver side)
Struggling to get one anywhere in PTA area.
It is a 2004 model
Michael
Rasmoes said:
Hi
It is a 2004 model
Have you tried BEMOW Spares
Diablo Jnr
Is the entire unit broken or just the movable switch section.
if its the switch that you use to operate the window, just get a unit from any E46 and change out the clip.
Pull out the leather bag around the gearshiff, it has clips at the bottom so you will need to give it a good tug, then unscrew the unit and swop switch.
hope this helps
