318 ti electric window issue
Quickie
hi guys... need some input.
having an issue with the windows on the ti. for both drivers and passenger side
the automatic down function does not seem to work properly. the button/window does roll the window up and down.. but not automatically open or close ..as in if you press it once it goes up or down.. not sure if u get this.
im suspecting a small electric gremlin here cause a few weeks back the boot switch also stopped working frm inside the car.. have to use the key only to open.
also.. the other night stopped at home left car idling and went to fetch something inside probably 3 minutes or so . got to car and odometer trip kilometres reset itself...as well as the clock/watch.
car still drives fine... normal performance and economy.
any idea were is can start to diagnose the problem.
jus my instinct. . tells me that it could be the battery.. got the car jus over a year and not sure when last it was changed. . but could it be??
Dnt wanna change then its not...
pls help
Quickie
okay.. the windows have somehow managed to s itself out.
This morning however I noticed that having the headlights on and when I put the back window demister on there was a dip in the lights... also when I put on the heater.
not sure wtf is going on now..
could the battery be goin?? and is this the tell tale signs.
were can I go to jus get this tested.
tmoney85
i have a E46 with same issues driver and passanger side, my driver side has completely stopped working, you and i in the same boat:argh:
