Small updates:
Gravel road driving protection:
The plastic wheel arch mouldings are doing an excellent job of protecting the paint from stone chips, especially when driving on gravel. The M Sport does not have this plastic protection, so something to bear in mind if you are looking to take an X3 on gravel.
As a counterpoint, here is my Macan with painted wheel arches. It has already picked up 2 stone chips. I will get them repaired and apply a VPS strip on each wheel arch.
The base X3 is better suited for gravel road driving.
Engine feeling a bit perkier:
Given that the Ford has been sold, the X3 is being used daily and on weekends. The car feels a bit perkier in normal driving and seems to respond better to throttle inputs. I will be keen to see how she feels on another interprovincial drive given that the engine seems to have loosened up a bit since the last long distance trip.
Minor trim issues:
Besides the flaking silver paint on the lower dash (as posted earlier):
- the rubber on the driver's interior door pull (not the handle, but the part you pull the door to close) is lifting off slightly. Will ask dealer to check at next service.
- I also noticed that the driver's door latch gets stuck slightly - when you try to open the door from the inside by pulling the handle, the door remains latched and requires a solid push to unlatch. The latch/catch mechanism seems to be sticking. Will ask dealer to check.
- The luggage cover edges scrapes against the D pillars on the inside of the boot/hatch (note that cover needs to be yanked towards you at an angle and then down into a groove). Since the luggage cover edges are black and the interior of the D pillars is white, these scuff marks are very noticeable. The luggage cover is a poor design and BMW should have either followed the more elegant and seamless design from the Mazda CX5 (the luggage cover opens and closes with the hatch opening and closing) or the straightforward sliding cover of Volvo. This is only an issue if you pack your X3 G01's boot to the brim - which I do, since my spare wheel takes up space.
- The front passenger window creaks when going down. Will ask dealer to check.
Besides the issues above, the rest of the car seems solid. However, the rear doors feel a bit too lightweight for a premium product.
Fuel consumption - based on my Fuelio.com logs:
Average so far: 6.9 l/100km
Worst: 8.45 l/100km
Best: 5.01 l/100km (long distance trip, mainly downhill)
Experience driving alone:
I took the car for an extended drive alone and really pushed it hard without having to worry about the welfare of passengers.
The car feels more fun to drive in this manner.
If pushing the X3 2.0d hard through twisty roads, it reveals a slight bit of RWD biased AWD character that puts a smile on your face - more so than when driving it in tamer conditions.
Alone on a quiet and twisty road, this is an SUV that you can enjoy and one that will make you smile when you give it the beans. You need to grab it by the scruff of its neck and it will reward you.
However, with a family onboard, you cannot really do this to extract that amount of enjoyment from the 2.0d.
If you have a family and need "enjoyment-on-tap", then the 30d can give you that without having to thrash it.
