2011 e90 335i N55 with F30 motor
francoisellis28
Hi guys need some help, I've blew like 3 radiators already and no one can help me to get the problem why it does that. BMW Ceadar change the motor but they used the old motors intake manifold with the old sensors. Don't know if that can be the problem or what. Any help will be greatly appreciated.
Twinz
Forum - Support
Too much air boost :smilebounce:
Hope you get it sorted. Blowing a radiator 3 times is unusual and scary.
Rayzor
You would need to follow the bleeding procedure to remove the air..
1. replace the Radiator
2. Top up with 50/50 coolant and distill water mix
3. Bleed procedure:
Recommend you use a battery charger
- Ignition on (do not start)
- Heater set to Max
- Blower speed set to Min
- Hold accelerator down for 10s
You should hear the water pump starting up and some noise coming from the expansion tank.
Important to check coolant level when done and repeat the fill and bleed procedure.
Hope this helps....:thumbs:
Nikhil
3. Bleed procedure:
- Heater set to Max
:withStu:
francoisellis28
3. Bleed procedure:
- Heater set to Max
Thanks will try.:thumbs:
