2008 X3 3.0si maintenance
Chrisdup8710
Hi All
Just bought the X3 with 169k on the clock. Just wanted to get a feel of how to best look after the vehicle mechanically. I've skimmed through the posts here and saw that if one looks after the car nicely, it can go forever. Any pointers/ things to look out for?
Straight six
One of the most straight forward & bulletproof engines BMW had ever built
Cooling system vital....expansion tank, hoses etc....
5W30 Shell Helix Oil (Cheaper at the dealers)
Now pics of the new new baby please......
Chrisdup8710
Thanks a lot! Will do so in the morning.
Something that has come up though, the master window switch failed today. The others work fine, as well as the mirrors. I checked the fuses and they are fine. What could be the problem?
And the run flat indicator also came on, but it doesn't even have run flats...
Chrisdup8710
Gizmo
Banned
You have the Si which has the N52 engine so I suggest you start saving for a new water pump and thermostat as they frightfully expensive, a visit to Carbon doctor will help too. Service the car more regularly and make sure tyre pressures are correct and that the tyre sizes are correct as these if wrong will put strain on the transfer case which is a weak point on these cars.
X3 is factory equipped with tyre pressure monitoring via ABS sensors, you have a flat/low tyre.
Chrisdup8710
What are we looking at for the pump and thermostat?
I checked the pressures for the tyre size (255/55R17) and it was low at the time. Pumped them to the requirement but the indicator still on. Any way of resetting it?
Gizmo
Banned
While stationary, press and hold the tyre button in until the light changes to orange, reset done.
