bybyM3
Peter@AEW said:On a separate thread there was a discussion of bearings being done.
Here is a good reason as to why you need bearings done on the S engines
I have used a vernier to measure which is 95% accurate as I do not have a 50mm digital micrometer so I would not be able to show you the measurements clearly.
Here is a standard not worn journal for the conrod.
Here is the worn journal that ran a bearing.
This journal is beyond cutting to clear the score marks as it will take the crank to extreme undersize.
In addition the crank was bent with runout of 0.2mm where the factory stipulates 0.002mm runout.
Impacabble work Peter
I do have an outer micrometer if you want to use it
