Hi all,
I am new to this forum and hope that someone can share their ideas on this topic. I tried the UK forum... uhm... :wrongforum:
Anyway, here goes:
There is a 'whooshing' noise from the engine area when changing up through the gears as I accelerate and momentarily lift off to select the next gear, or when I accelerate then back off. Have been told it's nothing to worry about as the noise is not getting worse, but again any advice would be gratefully received, if only to put my mind at rest.
About 2 months ago I changed my crank case oil breater to the new type (non-sponge), I cleaned my EGR and also removed my intercooler for a nice clean & presure test (Silverton Rads) before replacing it again
Ever since then (I might be imagening myself) I have this sound. It happens when the engine is hot or cold, boosting high or low. It only happens when the engine loses revs by depressing clutch or just back off on the throttle
It almost sounds like some vacuum of air going somewhere, or leaking somewhere.
If there are perhaps any newer updates on this behavior, please post a link to it - else, some ideas will help as well.
I am just concerned that prolonged use of the engine with this sound will cause damage to the engine
Anyway, here goes:
