2002 E46 M3 vs 2008 E92 M3 - Maintenance
Hashik86
Hi Guys,
Need some help...I've been looking at getting my first M, but I've heard that maintenance on an E46 and E92 are killer. What are the common problems and costs I should keep in mind when buying either? Would prefer the E92 simply because it's newer and I think sexier but the E46 is significantly cheaper and a boyhood dream...
Rommies
Hashik86 said:
Hi Guys,
Cant comment much on the V8
but from the e46 m3 - there is a few maintenance stuff you need to check:
- steering hoses
- vanos seals etc. (vanos anti rattle kit)
- valve clearances
- oil / exhaust tab disc needs to be checked / redrilled.
- rear sub frame may be cracked due to a lot of hard acceleration etc.
here is a few threads you can read through:
http://www.bmwfanatics.co.za/showthread.php?tid=59347
http://www.bmwfanatics.co.za/showthread.php?tid=59994
http://www.bmwfanatics.co.za/showthread.php?tid=52047
http://www.bmwfanatics.co.za/showthread.php?tid=59190
http://www.bmwfanatics.co.za/showthread.php?tid=55849
Last but not least...here is a good thread http://www.bmwfanatics.co.za/showthread.php?tid=51678
