2002 E46 330d Exhaust Manifold
PizzaBoy
Hi guys hope you all are well, do any of you know where i can get a manifold for my car in centurion area?
Thnx
Nikhil
What happened with yours?
The manifold from an E39 530d will also fit. Do not fit the stainless steel one from the facelift E46 as they crack.
PizzaBoy
Mine has a aftermarket branch on and this thing also keeps on cracking and the turbo keeps on coming loose as there is no space for locknuts
PizzaBoy
haha, the manifold that i have on was build, and it keeps on cracking on the welding, and it was build in a way that you can not put longer bolts in so that you can put lock nuts on it, so the bolts goes through the flange, into the turbo but is too short to go all the way through the turbo so that i can put a nut on it
a>
So you see those too bolts keeps on coming loose
so im just looking for the std manifold
