Actually i agree and disagree both at the same time lol
it depends what his pre-requisites are, im guessing that by looking at a 523i for 50k, i would imagine a car of 70k is out of the question ? guessing..
50k does not buy a 530d thats get in and go imho
also the 530d auto gearbox is wat more prone to failure
than the petrol auto boxes.
so service history on the 530d would be even more crucial... book value on
2000/2001 530d's is sitting at around 80k-ish right now.
the 530i's are also fetching high 60's and in the 70's and higher depending on mileage.
a e39 in manual might not be everyones choice, but it does eliminate 1 possible "expensive" catastrophe failure...
imho a lesser model with some change that you can spend on putting a few things
right, control arms,some bushes etc etc in my 2c is a more reliable proposition than a higher model thats stretching the budget where there isnt some change left to put a few things right...then begins the downward maintenane spiral..
but 50k does start becoming 528i money i would look into this!!
also it depends on the OP, performance,power etc may infact not be
primary factors...
consumption wise, yeah a 530d is tops. infact many consider it to be the best
e39 "overall". but potential for issues if you cannot TOTALLY verify pedigree
is a consideration
primary factors...
is a consideration
ChefDJ said:Hellrot...
There is an E39 528i on this forum with over 425k km on the clock. Engine and gearbox have never been opened. Vanos seals were done not three months ago.
This just proves that with proper maintenance the engine will outlast the shell of the car. It's more likely you'll have to replace door hinges etc before you have to do any extensive work on the motor.
If I were you, I would not go for the 523i unless it is from a family member or good friend that you can really get it at a bargain price for. 50k is a good price, but for that you can get a bigger engine in an E39 with the same mileage.
Go for a 530i or 530d. The 530i, in my opinion, will be lighter on fuel than the 523i as you won't need to use the engine as hard to move the body. Less revving. These cars weigh in at just under 2 tons so the more power you have, the better.
If fuel consumption is no factor, get a 540i in manual. This car is indestructible.
