Howdy.
I have noticed a slight pinging under hard acceleration. Landy idles at about 1000rpm which sounds high to me. Timing sounds too fast even at idle(gut feel). Speed sensor is buggered(or wiring leading to it) so motor only revs to 5k. Shouldn't the knock sensor back of the timing when it senses pinging?
Could it be that because of the missing speed signal to ecu that its now running in limp mode and discarding some inputs from sensors and running default settings?
Sent from my BlackBerry using Tapatalk
