Update, Techno came back last week for her new RHS fender lining and a few other things.
Fender installed.
Cape Town proof. :fencelook:
Old pork chop in place however 2 tabs are broken off.
Some other things to install. CCFL rings RHS ballast died and the only way to fix it is to buy another kit, at least he has spare rings and ballast.
LHS Mangled mech out, its riveted to the door...
New mech in.
Old caked on grease needs cleaning off first, what a PITA!
Glass re-installed with new clips and new grease.
Drivers side needed an adjustment, main screw mount, insulation and grease. Both front door cards got all new OEM door clips upon re-install.
Where's the baby?
There he is!
Re-greased for smoother operation.
After completion I took it for a relaxed 20km drive, its such a pleasure to drive even for a daily, suspension is comfortable, clutch doesn't kill you, gearbox shifts well, motor has plenty poke and sounds awesome, the car is stunning to look at, it would be a privilege to own this vehicle, your brother is one lucky bastard!
