Solo Man
What is the best method for bleeding the air out of the cooling system of this car. Parked the car on steep incline and filled slowly with bleed screw open. When full went for a spin untill the temp was on 12 o'clock , came home and parked the car. Will check tomorrow for water level (heater was on max - will it matter if fan is not working??) Please note it was the heater on max 32 degrees and the interior fan that is not working - the normal electric fan at the radiator is working perfectly .
