Technically speaking yes.
But for the love of cheese, nobody is going to pick that up. If you do not molest a wiring harness in the process, your good to go.
There are no airbags in the seats, but there are pre-tentioners on the seat, 1 on the passenger, and 2 on the drivers ( if memeory serves)
You can use the pre-tentioners that came on your seat, so the serial numbers and stuff will match, but just disconnect the battery, else you will have an airbag light, and unless you have a connection, your going to need to explain yourself.
